DT 770 Pro 32 ohm for PS4?
idkwhatimdoinglmao
21
I plan on buying a pair of the DT 770 Pro 32 ohm and I was wondering, would the PS4 controller be enough to power them? If not, what are some good headphones for gaming that can be powered by the PS4 controller? Also, my budget is 200 dollars USD.
32 ohm is compatible, will sound great. The PS4 controller uses a TRRS jack, CTIA standard so you can use plain-old headphones no problem. You can also get a splitter like this and you can also connect up a mic like the Zalman ZM-Mic1 or any mic with a TRS plug.
