I'm thinking of upgrading to more comfy headgear, currently have Marshall Major (1st version, got them for free so don't judge) and they are killing my earlobes for years now. I figured I would go with the popular BeyerDynamic DT 770 PRO, I am just not sure if I should get:
32 Ohm version and use my on-board Realtek ALC898
or 80/250ohm and get an external DAC/AMP for it.
I'm leaning towards the external DAC/AMP due to the interference noises-its not constant hum, but only when I hardware is being used, heavy GPU usage especially. I don't have a second line-out in the back so I'm forced to use the pins-cable to front of the case. Now I might attempt to finally solve this by running a shorter, shielded cable to the back (custom made) but before I spend time on that I figured I will ask:
do powered headphones make a big difference? is it worth to pick up the 80/250 ohm version and power it up externally?
