Motherboard does supply some power to CPU but for most purposes what really counts is only what it gets from 4 pin.do both connectors power the cpu?
Probably nope, but would need to know how the rails are split. Typically one rail goes to PCIe cable only while the other powers everything else but in your case I'm not sure if this PSU even has PCIe cable.so if the cpu needs more than 17A, it will draw current from both rails?
24 pin powers motherboard (and some parts directly connected to it like RAM) while 4 pin EPS powers CPU.
1 x Main connector (20+4Pin) 1 x 12V(P4) 6 x peripheral 2 x SATA 1 x Floppy 1 x PCI-E |
Features | 80mm low noise cooling fan Dual 12V outputs: 12V2 for Motherboard and peripherals; 12V1 for processor Industrial-grade protection circuitry prevents damage resulting from short circuits, power overloads, over voltage, and under voltage 80 Plus Certified is the newest standard in power supply efficiency. |
S12II 380w? Actually it's not dual rail 12v.
What do you want to power with a 14 year old PSU that's pretty bad for nowadays standards?
On a 14 yo PSU with very bad voltage regulation and probably sky high riplle. Don't do it! You're killing your hardware.i'm running a 12600k on it right now.
Yeah, 14 years ago it was acceptable in quality and performance.and it supposedly uses quality parts, and was a good performer.
At least 300 bucks CPU, 200 bucks motherboard and 100 bucks RAM. 600 bucks of hardware you want to power with 14 yo e-waste or new piece of garbage. It's your choice but don't whine when it kills your stuff.I get a new psu, it will likely have cheap china caps and no active pfc.
choosing between 2 evils, if I get a new psu, it will likely have cheap china caps and no active pfc.
I read some reviews of this seasonic, and it supposedly uses quality parts, and was a good performer.
Ouch. You know 12600K can draw over 150 W without overclock? That's more then your setup can deliver, which means you'll not get full power out of it with that PSU. If safety is something you ignore then maybe this can make you think about swapping it.i'm running a 12600k on it right now. Bare bones, no external gpu.
Why is that? Because you only want to spend $15 on a PSU from Alibaba?
Where was this? I'm not aware of any Seasonic 380W PSU reviews that have a full tear down.
Why are you willingly ignoring what people want to make clear to you?But I did just order this $15 crap .... https://www.newegg.com/evga-500-ba-100-ba-0500-k1-500w/p/N82E16817438188?Item=N82E16817438188
as a replacement for my seasonic.
here's one.
Seasonic S12II-380 Power Supply
Seasonic has been making quiet, efficient, high performance, power supplies for many years. The S12II series is their latest mainstream line. We test drive the 380W model on our torture track. It gets the checkered flag without a single glitch. August 16, 2007 by Mike Chin Product Seasonic...silentpcreview.com
and yes, I've never bought an expensive psu, especially for a barebones system with no gpu here.
Components within a PSU such as capacitors (Some of which are for smoothing ripple) don't perform as well after many years. Even IF the quality of the components is as good as the higher wattage S12ii units, at 14 years old I would not trust it with a new system, even a lower power draw one.do all good power supplies have crappy ripple and voltage regulation eventually?
There is literally NOTHING in that review that speaks to the topology, components used, build quality....
Crap? Actually... that's not bad considering your build. And a great deal too. It has full range APFC and is 80 PLUS Bronze efficiency. It's double forward, like your Seasonic, but at least uses DC to DC for the minor rails.
I wouldn't use it with a high end discrete graphics card, but even without the rebate that's a good price.
Just don't risk using it for 14 years like you did the last one. 😀
It's showing as out of stock for me.Spend some more and you get something better,
https://www.newegg.com/bitfenix-formula-gold-series-bp-fm650ulag-7r-650w/p/N82E16817376011
Just can't figure out why with the parts you have now $50 is too much to spend.
I didn't use the seasonic for 14 years straight.
It actually wasn't used in the last 7 years while I had a laptop.
good to know this evga might be a good deal.
but for sure there are no Japanese caps in this. That's why I called it crap. Most likely capxon teapo.
Hope it doesn't blow up and fizzle.
However, in my other pc, I have an ocz600mxsp which had china caps and it ran without issues, and is still running.
So you might be right if this lasts 14 years.
To me it says ,It's showing as out of stock for me.
and Free Shipping which is a small bonus.In stock.
OCZ... You have quite the collection of old PSUs.
Just means you're lucky enough. But than again with only an cpu/igpu to power you don't need alot of it. My worries come from what if you want to get a dedicated gpu? Or else why have an 12600K when not doing that?
It will.I wonder if the warranty-void sticker will fall apart if i try to peel it
