Dual band wifi card for Toshiba Satellite P845t-S4310
Oct 11, 2018
My Toshiba Satellite doesn't support 5GHz. What replacement network card will successfully replace my Intel Centrino Wireless-N2200 wifi card?
Emerald
The first thing you should find out is if your laptop manufacturer uses a whitelist in the BIOS of your laptop. If your laptop's BIOS uses a whitelist, it's possible that the Wi-Fi card you want to use may not be supported.
Similar threads
