Dual Channel Help!
i was wondering if i bought 2x of
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134045
would it be possible to run in dual channel? like 1 3 or 2 and 4
the motherboard gigabyte ds3 supports dual channel
or should i buy a dual channel kit
im also want to overclock an e6600 (2.4 ghz to 3ghz) do you think the ram i listed above will work?
thanks
Yes, two of those will work in dual channel. Dual Channel kits can sometimes be cheaper than buying sticks individually.
When you OC, you're gonna want to raise the FSB to 333. Set the RAM at 1:1 so it runs at 333 also. (the RAM multiplier should be 2)
