Question Dual channel problem ?
Nov 7, 2021
Hi i have a B450 Aorus Elite v.1 motherboard.
Im using corsair vengeance pro 8x2 3000 mhz RAM
Processor: ryzen 5 2600
The problem is when i want to use those rams in dual channel, i need to put them in slots 1-3 or 2-4..
But when i put them into those slots, my PC isnt opening at first.. trying to open itself for 4-5 times reset and sound of beep and then its opening but in 2133 mhz and alsoo in the performance/ram parts its writing: hardware dedicated memory:8 gb..
When i put my rams on 1-2 or 3-4 the computer is opening well also working as 3000 mhz, also hardware dedicated memory/70mb(which is okay) but in the programmes its showing that the rams working in single channel ?
There is a bug that dont let the open pc as dual channel and 3000 mhz at the same time..
Soo what do i need to do and what is the problem u think? Thanks from now for your opinions..
Lutfij
What BIOS version are you working with at the time of writing, for your motherboard? Per your motherboard's manual, page 9, you should be using slots DDR4_1 and DDR4_2 or DDR4_3 and DDR4_4 if you have two sticks of ram to play with.
On second thoughts, could you list your specs to your build like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS: include OS version(not edition) if you're on Windows 10
Nov 7, 2021
Thanks for welcoming, i think my mainboard is broken, 2 of my ram slots are broken, they are 4 and 2! when i put my rams 1-2 or 3-4 the computer is opening but 8 gb of my rams is not usable, also mhz is being 2133 automaticly.. When i put my ram 2 or 4 as single, computer is not opening I realised that on mainboard its writing dramm and cpu as red..
But when i put my rams as 1 3, the computer is opening and i can use at 3000 mhz but its single channel..
Motherboard:b450 aorus elite (Bios: f63 10/13/2021)
CPU:ryzen 5 2600
Ram:corsair veng. Pro 3000 mhz 15 17 17
SSD/HDD: xpg 8100 nvme m2 500 gb
GPU:gtx 1060 msi 6 gb
PSU:lc665ogpe power 650+80 gold
Chassis: raijintek water cooler and 7 fan
OS: Windows 10 pro 21h1 19043.1288
