Keep in mind the only CPUs that can run in SMP as dual socket configuration are the Xeon E5-2xxx chips, 4xxx chips, and 8xxx chips (these can run in 2-way, 4-way, and 8-way SMP respectively). You cannot run a Core i7 with another, though they will physically fit. You cannot run a Xeon E5-1xxx chip with another, as those are for 1-CPU systems. You should also be looking at the E5 v3 chips, not the v2 ones. Actually, here's a link to the ARK page:
http://ark.intel.com/products/family/78583/Intel-Xeon-Processor-E5-v3-Family#@All
With that out of the way, you can go with dual Xeon E5-2620 v3, each of which is a 6C/12T 2.4GHz part so you'd have 12C/24T @ 2.4GHz. No overclocking on these parts, that's what you'd get. Those are ~$420/each. For ~$440/each you can get dual Xeon E5-2623 v3 which would offer you 8C/16T @ 3.0GHz total (they're quad core CPUs). Keep in mind an i7-5960X is an 8C/16T 3.0GHz chip so this configuration is sort of equivalent to a 5960X while the previous one is not since it has more cores but at a slower clock rate. Which one would be better depends entirely on your workload.
Other interesting choices are:
At $420/each: dual E5-2620 v3 for 12C/24T @ 2.4GHz [28.8] [$29]
At $440/each: dual E5-2623 v3 for 8C/16T @ 3.0GHz [24] [$37]
At $670/each: dual E5-2630 v3 for 16C/32T @ 2.4GHz [38.4] [$34]
At $1160/each: dual E5-2650 v3 for 20C/40T @ 2.3GHz [46] [$50]
At $2000/each: dual E5-2667 v3 for 16C/32T @ 3.2GHz [51.2] [$78]
At $2150/each: dual E5-2687W v3 for 20C/40T @ 3.1GHz [62] [$70]
At $2700/each: dual E5-2697 v3 for 28C/56T @ 2.6GHz [72.8] [$74]
Where the first number in brackets I've added to mean the product of cores and speed (admittedly a crude metric for performance as cores don't scale linearly). The next bracket is the total cost per unit in the first bracket, so you see that higher performance makes each and every clock cycle cost more to obtain. Your best value is the dual E5-2620 v3 however let's not forget the 5960X as a single CPU, which at $1000 would look like this:
At $1000: single 5960X for 8C/16T @ 3.0GHz [24] [$41]
However, if you can drop the motherboard back down from a $490 dual CPU board to a more manageable $240 X99 board then your total cost is altered such that it's like getting the dual CPU board with a 5960X priced at $750 meaning the two numbers in square brackets would now be [24] [$31].
Personally I like the idea of toying around with multi CPU setups, but I honestly think an overclocked 5960X is your best bang for the buck option. The only things I see that would be likely to outperform a stock 5960X are the dual E5-2630 v3 and above setups which is a $490 board + $1200 in CPUs versus $240 board + $1000 CPU.
THG did a 5960X overclocking review and found 4.4-4.6GHz is typical. At that point the numbers in square brackets change to [35.2] [$28], so you'd end up needing at least 16 physical cores if not 20 or 28 to outperform it, and that's assuming that whatever workload it's being given can handle cores past the 8th in an efficient way.
