hyperGAME Prominent May 8, 2017 8 0 510 May 8, 2017 #1 Hello, I am using a MSI Night Elf B150M with no graphics card. Since the board only has a Dual DVI-D port I used a DVI to HDMI converter. But my Screen doesn't receive a signal. Thanks i advance
alexoiu Titan Nov 1, 2012 39,817 250 126,990 May 8, 2017 #2 Hi, New, or old setup? If new what other components using? Upvote 0 Downvote
hyperGAME Prominent May 8, 2017 8 0 510 May 8, 2017 #3 alexoiu : Hi, New, or old setup? If new what other components using? It's a new setup (My first actually) Components are: 8 GB Crucial CT8G4DFD8213 RAM Corsair CP-9020098-EU VS Series VS650 80 Plus ATX Power Supply (230V, 650W) Kaby-Lake i5 7500 Toshiba MQ01ABD100 1000GB HDD Sharkoon VG5-W Case Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 May 8, 2017 #4 The board might need a BIOS update for supporting the Kaby and you can't do it without accessing the BIOS. You need a supported CPU. Upvote 0 Downvote
hyperGAME Prominent May 8, 2017 8 0 510 May 8, 2017 #5 alexoiu : The board might need a BIOS update for supporting the Kaby and you can't do it without accessing the BIOS. You need a supported CPU. You might be right, but if the new CPU isn't supported shouldn't the debug LED (CPU not detected or failed) light up? Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 May 8, 2017 #6 Not necessarily. What are the 4 digits after B in the board's serial number (B1xxx)? Upvote 0 Downvote
hyperGAME Prominent May 8, 2017 8 0 510 May 8, 2017 #7 alexoiu : Not necessarily. What are the 4 digits after B in the board's serial number (B1xxx)? B150M Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 May 8, 2017 #8 Not the board's model, but the serial number http://www.msicomputer.com/msi_user/barcodeImage/MB_1.jpg Upvote 0 Downvote
hyperGAME Prominent May 8, 2017 8 0 510 May 8, 2017 #9 alexoiu : The board might need a BIOS update for supporting the Kaby and you can't do it without accessing the BIOS. You need a supported CPU. Thanks, I bought a Skylake Celeron now and I will see in about 2-3 days if it will work Upvote 0 Downvote
hyperGAME Prominent May 8, 2017 8 0 510 May 8, 2017 #10 alexoiu : Not the board's model, but the serial number http://www.msicomputer.com/msi_user/barcodeImage/MB_1.jpg sorry my bad B1608 Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 May 8, 2017 Solution #11 The board does need a BIOS update. The Celeron should solve the issue. Upvote 0 Downvote Solution
hyperGAME Prominent May 8, 2017 8 0 510 May 8, 2017 #12 alexoiu : The board does need a BIOS update. The Celeron should solve the issue. Thank you for your help Upvote 0 Downvote
