Hello,
I'm wondering if it's possible to force a raspberry pi 3 to connect both by ethernet and wifi simultaneously.
What I'm trying to do is set up a media server where I'm able to gain remote access to my content. Due to a problem with our ISP and having multiple routers bridged, I'm unable to use plex's remote access on the wired connection in the specific room.
When I built my PC, I went with a super cheap wifi card at once I knew I'd be wired 90% of the time. My PC is wired to router #2. Router #2 is bridged to router #1, router #1 is in the basement and plugged into the internet jack.This gives my PC full wired internet speed, however, it makes it impossible to remotely access plex from my PC over the wired connection.
The RPi3 is acting as a media streamer and plex server in the same room as my PC and is hooked to a TV and is wired to router #2 (just like my PC is). I want to leave it wired so that I can stream at top speeds when I'm watching TV at home, but if possible, I would also like it to wireless connect to router #1 in the basement so that I can also use plex's remote access. Is this even possible?
