Dual intelligent processors 5. Help?
hesoyam123
Commendable
Mar 21, 2016
hey, i have a i5 4690k and a 650V power supply.
I tried using the 5-way optimization in ASUS dual intelligent processors 5 to overclock. i only got the choice between 4400mhz and 4600mhz and chose 4600mhz(thinking it wouldn't set it to something that didn't work. now when i run stress tests the pc just shuts down. the cpu only reaches about 70c before shutting down. the OC voltage was set to 1.325V. i assumed that you could do the 5-way optimization again and reduce the clock speed and voltage but the button is now greyed out and i cant click on it. i really don't know what to do now. I also tried using only the TPU tuning but the settings get reverted back to 4,6mhz and 1.325V after i restart.
http://imgur.com/ia7aY0Q
Just uninstall that Ai Suite III. Its pretty useless and junk. If you want to OC just do it directly in the BIOS. I was able to Sync All Cores to 4.5Ghz at 1.25-3. I wouldn't go over 1.3V. After that run a stress test like OCCT and play an intense game at the same time. If it doesn't crash, you can try lowering the Voltage and try again.
