Dual Intelligent Processors 5 set to default HELP!
CGPretty
11
Hello first thanks for reading. okay i need some help, i used the al suite to overclock my cpu and it increased by 17% and now my chip is running hot and im pretty sure its over volted which isnt good (of course) so im wondering... is there any way to rest the damn thing to the stock settings?
I'm pretty much 100% sure AI suite has reset button.
Failing that, you could pretty much google default clockspeed/voltage based on processor type and set to those.
Edit: case in point, FAQ shows screenshot of "default" button.
https://www.asus.com/support/FAQ/1012153
If you clicked the 5 way auto thing, it auto-clocked all different sub-sets, so visit each page and set them to default.
Thanks for the reply. you info you supplied is useful, although mine does not include the default tab, maybe because I'm running on a newer board?
