Hello everyone,
Currently I am using Dell u2412m with SAPPHIRE HD 7970 GHz. I am planning to buy a new monitor that works at 120Hz or higher for 3D bluray. However, 120Hz monitor requires dvi-d connection. Since u2412m doesn't have HDMI, it's connected to HD7970 through dvi-d. Thus the only dvi-d port of 7970 is occupied.
Luckily, I am using i7 3770k and Z77X-UD5H mobo, so I was wondering if this works:
Dell u2412m connected through dvi-d to mobo, works at 1920*1200 60hz
a new monitor connected through dvi-d to 7970, works at 120hz
Do I need to enable iGPU or install any software? What kind of settings do I need to let them work together?
Thanks !
Thanks !
