dual monitor cause my cpu temperature increase???
kyoekyar
27
I just upgraded my monitors to dual monitors. 2 of 27" LG monitors. My cpu core temperature is now about 55C to 60C. before it was around under 40C.
Do I need to worry about it??? 🙁
Thanks
There isn't any reason that I'm aware of that would cause your CPU to have increased load due to another monitor, however if your other components (graphics card in particular) are running at a higher temp the passive temperature of your PC might increase which could be running your CPU hotter. Check the temps of your other components.
GPU core temperature is only 28C.
by the way, my current cpu load is 40% (it's running speed show 3.67 GHz) and memory usage is 33% (12GB total). anything wrong?
