Dual monitor connection not working. DVI and VGA ports
javerybrinkley
Im having problems using dual monitor. I have a Hp pavillion p2 1310..... it has multi display capability. It has a DVI-D Port and a VGA port. I plugged both ports into both monitors and only one monitor (VGA connection) is working. Please help
AMD Radeon HD 7340
Your monitor may have the wrong type of DVI port.
DVI-D output is digital only, so the DVI input port on the monitor must be DVI-D or DVI-I. If the input port on the monitor is DVI-A that's analogue input only and won't work if it receives a digital signal.
You can identify the type of DVI port on the monitor by referring to these pictures: http://www.rm.com/support/technicalarticle.asp?cref=tec1484059
