Dual Monitor: Diff Wallpaper Per
sh1ft3d
276
I run dual monitor at work, which is actually consisting a laptop (secondary) and a 19" LCD monitor as primary. Is there a way to have different wallpaper on each? There's gotta be a way, but I don't think you can using built-in Windows stuff... maybe there's a prog out there that would let you? Right now if you apply a wallpaper, applies to both screens.....
defenderofcows
This is not really a clean solution but there is a way to get the two screens to show different pictures.
merge the two wallpapers you want to use side by side. e.g. if your monitors are each at 1280*1024 resolution, take two 1280*1024 images and merge them to a single 2560*1024 image.
Set the image as desktop background and set "position" to "tile".
*If you have two different resolution monitors this might not work very well. I have never tried it.
