Dual monitor fps drop
Pedro Monteiro
126
So since i got my new graphics card somehow i feel unsatisfied but i think theres a problem in here, whenever i use Dual Monitor, if i turn on a stream 60fps on my secondary monitor and play league of legends on the main monitor. Sometimes both main monitor and secondary monitor start lagging, not hard lag but there are some frame drops. Is there a way to fix this issue ? Thanks for awsnering.
Resolution on monitors:
1920x1080 Main Monitor
1280x768 Secondary Monitor
These are my specs:
CPU: i7 2600K
GPU: GTX970 4GB DDR5
Board: ASUSTeK P8Z68-V LE
RAM: 8GB DDR3
Supply: Hummer80 700W
I think your problem is that your GPU is also rendering/buffering the stream data packets
as well as rendering LoL. This is common, as GPUs are often automatically dedicated
to render streaming vids. Try goin to your graphics manager control panel and change the graphics
dedication of your web browser/ streaming software to integrated graphics, in this case your HD3000.
And the GPU to LoL. It may also be worthwhile to check out any other programs that use the GPU on your computer.
Can you tell me the steps i need to do that ? Cause i don't understand how i can change my browser gtx 970 to hd3000 ? Or if you have a guide please link it to me, thank you very much sir.
I know how to do it on my streaming service (OBS) just need to activate quick sync. But i don't know how to do it on the browser.
So go to your Nvidia Control panel. Im running version 8.1.760.0.
Then go to the tab "manage 3d settings"
There you'll find the controls to dedicate the gpu/intel graphics to which programs of preferrence
Also theres Global settings for which general gpu to use.
So i did that and, i do not have any option to change the graphics card... And im using the exact same version of your's.
I am using a desktop.
I can send you some pictures of my nvidea panel.
http://gyazo.com/85e9898e42ffe9d79c8ac8ca3713081f
http://gyazo.com/3eeb6fddf10d3f1e5438e9655f5b6408
Sorry for late awsner... didn't come to forum
Well my fix was using windows 7 64-bit with basic theme that disables aero.
For some reason when it comes to aero in windows 8/8.1/10 i always lagged dual screen, but if i go to windows 7 basic theme i don't really lag.
