Dual Monitor help PLEASE
watters1996
87
Hi Guys,
Basically i have my normal AOC pc monitor connected to my graphics card through VGA (1080p) and the picture quality is absolutely fantastic.
What it is I've got an LCD 24" TV here which is full 1080p and ive plugged it into my graphics card through HDMI but the quality on the hdmi tv is terrible, the picture is full screen but the text and writing is all fuzzy and blurred. how can i fix this?
I have AMD vision engine control centre on my pc if that has a setting ive missed.
The graphics card is a Asus HD6670 1GB GDDR5
I want it in the extended monitor setting so i can drag a windows over to the monitor and have 2 screens at once.
HELP!
Any res works with the VGA up to 1440 x 900, its a LOGIK l32HE23
It has only 1 PC and it has 2 HDMI...my pc has another PC output but it doesnt work due to its onboard
It's a 720p. The specs on it:
Resolution 1366 x 768
Text will be blurry due to a 32" TV at that resolution. That is the resolution of about a 19" monitor which you are spreading out over 32 inches.
If you want sharp text on a a TV over 22" or so, you'd need a 1080p set.
Changing the contrast and brightness may help, a lower brightness and contrast helps with making the text better. Not by much, but a noticeable difference.
