Dual monitor help
xRorz
80
Alright so, I have a GTX 770 2gb which I'm hoping to be able to use dual monitors with? Can I do this? It has a DVI-D Dual Link and a DVI-I Dual Link. I have very little knowledge when it comes to DVI cables so sorry if this is a really stupid question. Am I able to use 2 monitors as long as they both use DVI will I need a splitter or what?
Also, the cable on my monitor is DVI-D but it also works in the DVI-I Dual Link. Is there anything wrong with this?
First, They are both DVI output (Dual Link will simply allow you to have double bandwidth, to support resolutions above 1920x1200)
DVI-D, is only supplies a Digital signal, while DVI-I will supply a both a Digital and an Analog signal. The analog signal will be use with a DVI->VGA adapter.
So if you are connecting them to DVI displays just plug one monitor into each port.
