I custom built my PC with the extreme guidance of a friend and it was been awesome! It however has come time for Dual Monitors to help navigate for Streaming. BUT I ran into one problem. I have only ONE DVI Port. No VGA.
My Card: https://www.newegg.com/Product/Product.aspx?Item=9SIA1UH4VD1575
As you can see it has only one DVI-D port, 1 HDMI, & 3 Display Port 1.4 (Uncertain what this is)
CAN I use the single DVI port for one monitor and then use a HDMI to DVI cable for the 2nd monitor? OR DisplayPort to DVI Cable?
IF NOT, is there any other way around this besides buying a whole new card?
