Dual Monitor Issue (Solved)
Rmhorgan
I've managed to fix my own problem, but I don't know how to delete this thread.
Hi Guys,
(Apologies if this is in the wrong forum section)
I run two Asus monitors on my pc. I recently disabled the integrated graphics card because certain games were trying to run off it rather than my Nvidia card.
However since disabling it one of the monitors no longer works, so I found a fix for the game issue elsewhere and went to re-enable the integrated card, but when I do I get both monitors back for a few seconds, and then they both turn black and I then can't get any picture until I restart my PC.
When I go back to the device manager, the integrated card has disabled itself again, re-enabling causes the same issue again.
Does anyone have any advice on a possible fix for this?
In simple language :)
Thank You.
MERGED QUESTION
Question from Rmhorgan : "Dual Monitor Issue (Solved)"
Hi Guys,
Thank You.
(Also I have to unplug my monitors and plug them in after powering up every time I turn my PC on otherwise they do not display anything, although this is annoying I've gotten used to just doing it at this point, so any suggestions on that also)
