I am using a VGA cable for my main monitor and decided to buy a HDMI cable and connect my TV to my PC as my secondary monitor. After I bought the HDMI cable, I connected it immediately to my TV ,everything works fine but then I tried switching the cables, so my main monitor is now connected to my PC through HDMI cable while my TV is connected through the VGA cables. But now I can't change my main monitor resolution into 1600 x 900 (which is the resolution I used before switching my cable). The only maximum resolution available is 1366 x 768. I can't even change the refresh rate up to 75hz. Last time when I am just using a 1 monitor I can go up to 1920 × 1080 75hz. How do I fix this? Tried updating my drivers and it doesn't work. But when I use my VGA cable for my main monitor and HDMI to my TV, I can maximize my main monitor resolution up to 1920 x 1080. How to fix this because I want to use my HDMI cable for my main monitor.
