Question Dual Monitor Management/Software ?
acadia11
1,217
147
19,460
I picked up a Hyte Y70 Touch. It's kind of gimmicky but after using it first hand, but eiher way is there a solution / software that allows you to have distinctive power save profiles. Ie I want to lock the screen on the hyte touch but not turn it off, while I want my main monitor to go into power mode and turn off as normal. In this way the display on the case is always on. They'd act as independent screens?
Do you have the Hyte Y70 Touch User Manual?
https://hyte.com/nexus/how-to
[Be sure to verify that I found the applicable manual.]
That would be the starting point. There may be some references regarding lock screen and power saving options.
There is also a reference in the link to the Widget Gallery. Perhaps there is a utility of some sort that could be used.
Lastly, you may have the options to use some hot key combinations or macros to implement the stated requirements.
Be sure to check the GPU's control panel and the main monitor's documentation as well. Especially if the main monitor has its' own set of drivers and some related set of utilities.
