Dual Monitor Mount: Two Different Monitors
bensaun
I have an annoying predicament, which I desperately need help fixing. I have recently bought two different monitors(one 24" Samsung, one 24" Asus). I want to mount the both with a cheap dual monitor desk mount. However, the VESA mounts are both at different heights, which the mount that I want will not adjust.
Is there any simple bracket that I can find to convert the height of my VESA mount on one of the monitors?
Any help would be great! Thanks.
The mount that you 'want' will apparently not work with the monitors you have.
So...
Either change monitors, look for a different dual mount, or if you are really handy, you could create an aluminum plate to adjust the height on one of them.
Why are you using a 'cheap desk mount' with 2 x 24" monitors? Get something solid.
Reactions: Scionwest
