[SOLVED] Dual monitor physical connection alignment?
MKDLMR
65
Is there any sort of physical clip for holding two monitors side-by-side? I have a dual monitor setup and they are the exact same make and model, but with highly adjustable stands they always seem a little "off" [crooked, turned, etc.] instead of being perfectly side-by-side.
I've thought of painting a couple paint stirrers black and taping them across the tops and backs of the monitors, but that would look tacky. Is there anything anyone would recommend?
Thanks!
Looks like you have a 100mm vesa mount for those. You could do a custom stand with a long backplate, pre-drilled for the vesa mounts. If you drill the backplate correctly, the two displays should be aligned.
-Wolf sends
In retrospect, no, there isn't anything that you're speaking of, unless you're looking for an aftermarket arm setup for the monitors that would help align the monitors. Also, there can be minor tolerance issues during manufacturing which is why you might find two monitors being the same make and model being slightly off, even the panels backlighting.
