C cal9777 May 16, 2018 4 0 10 Jun 12, 2018 #1 My PC only has 1 hdmi port, would it be possible to use the VGA port at the same time to have dual monitors?
Solution ffg7 Jun 12, 2018 if your computer or videocard has vga besides hdmi then yes on running dual monitors.
ffg7 Judicious Apr 7, 2015 5,924 2 34,665 Jun 12, 2018 Solution #2 if your computer or videocard has vga besides hdmi then yes on running dual monitors. Upvote 0 Downvote Solution
C cal9777 May 16, 2018 4 0 10 Jun 12, 2018 #3 ffg7 : if your computer or videocard has vga besides hdmi then yes on running dual monitors. yes, im currently using the HDMI for my monitor but was looking into adding another, thanks so much! Upvote 0 Downvote
