Dual Monitor Problem With background
cheetaz
19
Hello, so recently I got a brand new ASUS VG248QE. I already had one before, so that was my 2nd one, so now I have a dual monitor setup. They are both connected by display ports, and both on same Hz and resolution.
The problem I am having is that the background and basically everything i move from one screen to another is shifted about 3 inches down from left screen to right screen. So basically, If i move an application from the left monitor to the right one, then it will not move on the same horizontal line, but it will be shifted about 3 inches down, which is really frustrating. Since that is happening, the mouse gets stuck between monitors on the top 3 inches of the left side of the right monitor, and 3 inches on the bottom of my left monitor. It is really weird, the 2 monitors were fine for about an hour, and then this suddenly happened. I got no idea if its my Graphics card which is a EVGA GTX 1060 6Gb, or if something is wrong with the display ports? Please Help!
This is an image of what I got going on, if I try to select something with my mouse from one screen to another, this is the 3 inch distance difference that I am talking about. http://imgur.com/a/pAcYj
Right click desktop > display settings. Make sure they are lined up correctly. Arrangement can also be changed in nvidia control panel.
