[SOLVED] Dual monitor problem
Borko1
77
I think it's a GPU problem, that's why I'm posting it there. I posted this in Displays subforum too but no solutions at all.
It's basically the problem of this guy: Link
CPU: Ryzen 5 1600 AF @ 3.2GHz
GPU: Sapphire RX 580 4GB Nitro+
RAM: 16GB DDR4
Mobo: ASRock B450M Pro4-F
Display 1: Samsung S22F350 @ 75Hz (overclocked)
Display 2: ASUS V193HQL @ 60Hz
Both displays are tested and are working correctly, drivers are the newest. By the way, this also happens when running a stress test, so it may be not frequency related. Also I'm using HDMI to VGA adapter for the second monitor. Thanks in advance.
Do you have another adapter to try or a proper cable without an adapter? There are cables that do the conversion with their own "adapter" embedded.
