Dual monitor set up help!
army1506
99
Ok, so I've asked this question before and everyone seems to be dancing around the answer... So I'm going to try and make it as simple as possible...
I have two monitors with hdmi ports on them. Well my graphics card only has one hdmi port... But my graphics card does have 2 DVI ports. But one is a dvi-I and one is a dvi-d port. What I was going to do is just get two hdmi to dvi cables. But people have told me they do not make dvi-I to hdmi cables... So how do I have a dual monitor set up with this graphics card
Graphics card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127696
army1506
99
If I do that, will there be any difference in picture quality? Like I mean, will the monitor with just the hdmi cable have better picture quality than the one with the dvi to hdmi?
army1506
99
Can you give me a newegg link to a hdmi to dvi-d dual link cable? I've searched for them but couldn't find it on the site
Vxshifter
94
This should solve your problem http://www.newegg.com/Product/Product.aspx?Item=N82E16882241139, but don't buy it straight away I'm entirely certain so wait for somebody to agree.
Edit: Connect this new cable into your Dvi-D port (http://www.google.com.au/imgres?um=1&hl=en&safe=off&sa=N&tbo=d&biw=1920&bih=1018&tbm=isch&tbnid=gO4STkioaV-yVM:&imgrefurl=http://www.playtool.com/pages/dvicompat/dvi.html&docid=B_FyYI1Ee-eCMM&imgurl=http://www.playtool.com/pages/dvicompat/sldldvi.jpg&w=610&h=620&ei=kOXLUNCPJYnliAfx4IAY&zoom=1&iact=hc&vpx=323&vpy=113&dur=463&hovh=226&hovw=223&tx=147&ty=108&sig=105014771882692524502&page=1&tbnh=144&tbnw=142&start=0&ndsp=60&ved=1t:429,r:2,s:0,i:94) then connect your HDMI into your HDMI port then connect the rest into your displays.
