Dual Monitor Set Up. Primary Monitor B&W/Greyscale.
Coltonace
Alright, so I have a dual monitor set up. It's all fine and dandy except about an hour ago someone ran my microwave while I was enjoying some DayZ. Old house, shitty breakers; breaker flipped. After turning back on the breaker in my house and booting back up the PC, I came to find that my Primary monitor is grey scaled. Second monitor is handy dandy. Not sure what the issue is, but I do believe it is a computer issue and not a display issue. Whenever I pull up the menu or change the source of the display, those are in color.
I started using a program called vibrance.gui the other day so I could add some saturation to DayZ's washed out colors (Looks Great BTW); however, this was running when the power went out and thought maybe it had something to do with the problem. Basically the program alters the NVIDIA control panel controls but can specify the levels of saturation per program. So I opened the NVIDIA Control Panel and all the settings are as they should be, so I don't see any issues caused by this.
I've tried restarting my pc and jostling my HDMI's, nothing has worked yet and I'm out of ideas.
Fixed the issue! So it must've been an issue with the VibranceGUI. I rechecked my NVIDIA Color settings again and for whatever reason decided to fidget with the 'Hue' Slider and VIOLA! Color was back! Strange problem, strange fix.
