Question Dual monitor set up problems
GimlisGHOST
Commendable
Apr 3, 2017
6
So i have a weird problem in which im trying to set up dual monitors. I use a RX 5700XT with a Ryzen 5 1600 and when i have both monitors plugged in only one will work but if i unplug one the one plugged in will work. For example if monitor A (main) and B (secondary) are both plugged in only monitor A will display but if i unplug monitor A, then monitor B will display. Monitor A (1440p) is using a Display port and Monitor B (1080p) is using HDMI. I had it working at one point but then i restarted my computer and now the set up will not work. Cables are good becasue each monitor will come one without the other. Thanks in advance for help
Edit: seems the "fix" was to uninstall the gpu from device manager and reinstall manually.
