Dual monitor setting
hiimyourfriend
126
Hello,
I got two monitors and I have only 1 type of cable. So I am planning to plug it into GPU area and Motherboard area. But the Motherboard slot doesn't work , only GPU slot is working. Is there any ways to make it possible? I heard you can set it in BIOS but I don't know much about it.
Help please, many thanks.
Sorry for the late reply.
It works when I use DVI and Display Port together into the GPU slot, but Display Port isn't mine so I have to return. That's why I'm finding a way to do this by plugging one into the motherboard slot.
GPU - GTX 1060 / Titan X
By this, I don't think we have to worry about whether it's compatible or not. Because my GPU's pretty much can do anything. What I'm not sure is, the BIOS. I tried enabling IGPU thing in BIOS but it didn't work.
