Question Dual Monitor Setup Advice for purchasing.
Nov 24, 2019
1. What Is Your Country Of Origin?
UK
2. What do you plan to do with this monitor? (ex. Games, Movie Watching, Photo Editing, etc.)
Gaming,youtube,streams. general email and spreadsheet work.
3. What resolution and screen size do you want?
I am after 2 monitors at 24"
4. What refresh rate do you want? (ex. 60 hz , 70 hz.)
144Hz on the main monitor
5. How much are you looking to spend?
£400-450 tops on the main monitor.
6. Brands Preferred (ex. Samsung, Acer, Asus, AOC, HP, Viewsonic, etc. )
N/A
7. Brands Not Preferred (state reason why)
N/A
8. Are You Buying More Than One Monitor?
Yes
9. How Many Displays Can Your GPU Support Maximum? And what GPU and driver version are you using if applicable?
RTX 2080TI
10. What Port Do You Want To Connect To (ex. DVI-D, HDMI, etc).
Displayport
11. Is This Monitor A Primary Display Or A Secondary Display?
Primary. secondary also required.
12. Is This A Secondary Display For A Laptop?
No
Hi All, I am looking at purchasing two monitors. I have three in mind at the moment.
Dell S2417DG
Acer Predator XB241yu
Aoc Agon AG241QG
What i am looking for is some advice on which one to recommend. Also what monitor can i pair with it for a secondary monitor? Second monitor will have my work laptop connected,console or second screen for my PC. Worst case scenario I will buy two of the same monitor from one of the above. but I am wondering if there is a monitor that would be 1080p/60hz for the secondary display that would look the same as one of the above as I would really like the two to match.
They will be mounted on an arm on my desk so will be side by side.
Thanks in advance.
