Question Dual monitor setup help ?
Sep 8, 2021
So I have a Sapphire DUAL-X R9 280 3GB that has 1x DP 1.2, 1x Dual-Link DVI-D, 1x Dual-Link DVI-I and 1x HDMI 1.4a. I'm currently running one monitor Benq XL2411Z at 144Hz (Full HD) plugged through DVI-D to DVI-D (only supported option for 144Hz).
I want to buy 27'' monitor MSI Optix G273QF (Quad HD) that has 1x Displayport 1.2 and 1x HDMI 2.0. If I connect this second monitor through DP to DP will it work on 144Hz (or higher? second monitor supports 165Hz). Or simpler question will dual monitor setup work when connected DVI -> DVI and DP -> DP, because thats my only option if I dont want to run one of them on 60 Hz (Benq only supports 144 through DVI, and dont want to deal with display stuttering problem due to different refresh rates).
