Dell Optiplex 7010 Windows 7
I'm trying to mirror two monitors to display the same image. The pc monitor #1 is connected using a DVI cable off the graphics card. I ran a 50' VGA cable to the other monitor.
For some reason, i can't get monitor #2 to display anything. its just blank. I've tried using VGA splitters with DVI ends but then monitor #1 goes blank and 2 displays the desktop screen.
I even tried connecting the VGA directly to the monitor itself, just to cover everything but no luck. Also, when i try to duplicate the displays, it gives me an error message that says "unable to save display settings".
I thought the graphics card had a HDMI input next to the DVI but when i went to install a HDMI to VGA adapter, the connector didn't fit. I've attached a picture of what i thought was the HDMI input.
Any ideas? Or does this graphics card need an upgrade?
