Dual monitor with 1440p and 1080p monitors
Sho Co2
Commendable
Oct 8, 2016
34
Recently I've been finding myself alt-tabbing a lot when using my computer for coding, modelling, etc so I figured to grab a second monitor. I decided that I'd want to get a 1440p 144hz monitor.
I currently have a ASUS VP247 (1080p 60hz 24") connected to my pc. I'm deciding between getting a second 24" 1440p 144hz monitor or a 27" one instead. I do also want my setup to still look clean as before, so I'm not really sure how a 27" would look next to a 24" monitor.
I also read online that 27" is the standard for 1440p monitors. I'm not sure how a 27" would look next to a 24" aswell as if a 27" is a necessity, what would you guys suggest?
Also, I'm having some trouble finding a 1440p 144hz 24" online (in Canada), maybe could somebody list a few recommended options for both 24" and 27"? I use my pc for both gaming and 3d rendering/modeling and coding. My pc should be capable of running both monitors at once, I listed some of the specs below just in case. Thanks in advance.
PC specs:
GTX 1080 G1 GAMING
Ryzen 5 1600x
Trident z rgb 16gb (2×8gb) 3000mhz
If you buy a second 24" monitor, the physical size will match.
But, because of the higher density of the 1440P monitor, the text will look small by comparison.
When you drag a page from one to the other, this will be very apparent.
I like the 27" 1440p approach better.
It will give you more immersion in gaming and the text sizes will be more similar.
I have a 40" 4k monitor along side a 30" 2560 x 1600 monitor and it works very well.
You get used to it.
You get used to it.
Thanks for the response, is there any specific monitor that you'd recommend? Ive got a budget of under $700 cad before tax
