Dual Monitor with Radeon Sapphire HD 7770 GHz Edition, is it possible?
davideeeeh
If yes, how? (He plays with a PC)
I'm writing on behalf of my brother, we are both quite rookies about computers so I apologise if the answer is noobish!
I think they support up to 6 displays with the Eyefinity feature. Depending on what display connectors do you have on your card, but for example you could use a DVI and a HDMI cable.
and which signal ports of the graphics card are used?
If one of the monitors is connected with a DVI-D or HDMI port it won't work without a converter, since VGA is analog and HDMI/DVI-D are digital.
What are the exact models of monitors?
EDIT: ok, I see the video card has a DVI-I, HDMI and Display Port 1.2 available, so you must be using a converter of some sort. What's the setup? which ports are you guys using?
