Dual monitor with Sapphire HD 7850
Stomp09
48
Hi all,
I've been searching around the web, on how I can get dual monitors going with my 7850. I have two vga monitors, one that i currently use with the card using a dvi to vga adapter.
Im trying to get the right adapter to get my other monitor up and running. I tried a hdmi to vga adapter but that doesn't work, because the signals are completely different apparently :).
http://www.ebuyer.com/390921-sapphire-hd-7850-oc-2gb-dual-dvi-hdmi-displayport-pci-e-graphics-card-11200-14-20g
Any help how I can get two vga monitors running on this card would be awesome.
Thanks alot
No he doesn't, hes not running dual 1440p or something. Its just 1080p. Passive is enough. What you do need to find is an adapter than has a single minus sign, and not a plus sign.
