Question Dual Monitor won't work
Dec 2, 2021
Monitors can work if only one is connected, but not simultaneously.
[background]
I built a work PC with Asus TUF B500M-plus and AMD Ryzen 5600G, with no GPU. This AMD CPU has integrated graphics. Mobo has 1x HDMI and 1xDisplayPort. Samsung Monitors (same) have 1xVGA and 1xHDMI port. Using a DP->VGA adaptor for one of the monitors and HDMI-HDMI for the other one. IGPU dual monitor enabled in BIOS.
When I connect both monitors, only DP->VGA monitor works, and the HDMI-HDMI one receives no signal. When I unplug DP->VGA monitor, the HDMI-HDMI one still has no signal but will work if I restart my PC. So it seems the DP->VGA is prioritized and overrides the HDMI port.
Should I replace one monitor with a Dell monitor that has DP instead of VGA? Or there is still some hope?
Thanks!
Dec 2, 2021
Did you enable dual-monitors in Windows (not just BIOS)?
Do both displays appear on the Display Settings main screen? If so, scroll down to Multiple Displays and make sure it's enabled.
-Wolf sends
Windows 10 display setting is greyed out on display mode as the system can't detect another device... My guess it's not a windows setting but rather Mobo issue
