Dual monitor works, then they both go sleep and seems no response from GPU?
PedramCarter
270
I'm running a 1920 x 1080 and the other one is 1600 x 900, I'm trying to make it work for educational purpose but it fails.
I have an r9 290x
12 GB ram 8350 processor.
It usually lasts about 10-15minutes sometimes way less and they both die. I try to test to see if the computer itself was functional maybe a gpu fail or something or the monitors use too much resources but it didn't work. The computer was completely not responsive, no noise can be heard I can't even restart using hot key on my keyboard. I can't do nothing even power button doesn't work I have to hold it. Once I hold it it turns back on and works normally. If I have one monitor disabled this doesn't happen including playing top spec games. I'm running windows 8.1.
There used to be a time where GPU reviews checked power consumption scaling with the number of displays connected to them and back then, GPUs often consumed 5-10W more per extra display.
The other thing I can think of is clocking issues: on my HD5770, if I mess around with clocks with two or more displays attached, PowerTune often ends up setting the GPU/memory clocks far too low to support the multiple output streams, which causes display corruption on the secondary/tertiary displays and sometimes cause the GPU/drivers to crash. The same thing happens when software starts using a video overlay: the GPU drops to 2D/idle clocks...
Not instantly, like depends sometimes about 10minutes later.
my current specs that im building.
Vantage Midi ATX PC Gaming Tower
(The cooling system is developed for cooling throughout
4 x Built-in 12cm Fans (3 x Blue LED) will keep your components cool
Water Cooling Ready *not included* )
Processor (CPU)
AMD FX-8350 4.0GHz Socket AM3+ Octo Core
Motherboard
ASUS® M5A97 R2.0 (DDR3, USB3.0, 6Gb/s)
Memory (RAM)
12gb
Graphics Card
4GB AMD RADEON™ R9 290X - DVI, HDMI, DP - DX® 11, Eyefinity 4 Capable
(battlefield 4 edition, free bf4 included)
Memory - 1st Hard Disk
1TB 3.5" SATA-III 6GB/s HDD 7200RPM 32MB CACHE
1st DVD/BLU-RAY Drive
24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Power Supply
XFX 650W PRO650W Core Edition.
Processor Cooling
STANDARD AMD CPU COOLER
Sound Card
ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking
10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
USB Options
MIN. 2 x USB 3.0 & 4 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
That's what I was thinking, but he said it only happens with 2 monitors plugged in, not one. I don't see two monitors affecting heat in any way, especially since gaming is on one monitor.
I was thinking the same, I use 1 monitor while gaming, the other one is off, this can simply occur with me being on the browser and browsing the internet.
The other thing I can think of is clocking issues: on my HD5770, if I mess around with clocks with two or more displays attached, PowerTune often ends up setting the GPU/memory clocks far too low to support the multiple output streams, which causes display corruption on the secondary/tertiary displays and sometimes cause the GPU/drivers to crash. The same thing happens when software starts using a video overlay: the GPU drops to 2D/idle clocks regardless of GPU load, causing momentary display corruption and occasional GPU/driver crashes.
