I am trying to get a dual monitor set up working. At the moment the first monitor works fine without issue but I cannot get the second one to work. I believe there to be 2x VGA ports at the back of my PC (see pic below) but it does not work when using a VGA cable with it. I believe my graphics card is able to use 2 monitors as it says I am using 2048/4096mb of the "total available graphics memory" in the windows settings.
I have posted pictures below which will give you a visual idea of the problem along with a link to my previous thread which was unsuccessful. Thanks for your time.
http://www.tomshardware.co.uk/forum/id-3034454/dual-monitors-detecting-monitor.html#17873781
https://gyazo.com/91f0b8db40428cce015fe28dae44cc4f
https://gyazo.com/d09a72e89cf2b34acc089b4a9174fd93
