dual pc streaming mixer setup help
nisidotatosp
4
Hello people,
i am trying to connect a xenyx q502usb mixer to 2 pcs and would like some help.
I have connected an xlr microphone to the mixer. Then, i connected an 2ble rca to 3.5mm cable to the ports as shown in the picture to the mixer and to the line in of the streaming pc.
https://ibb.co/iqTNiy
This works. The obs is listening to the mic. all is good.
Now i would like to learn how can i connect the headphones of my gaming pc to the mixer and effectively transfer sound to the streaming pc, because the viewers could not listen to in game sounds.
Thanks in advance
You will need to go from speaker out of pc to a 1/4 adapter on the Line in, 1/4 adapter on the main out to streaming pc line line. You will want (more of a NEED)...
You will need to go from speaker out of pc to a 1/4 adapter on the Line in, 1/4 adapter on the main out to streaming pc line line. You will want (more of a NEED) to get a Hum Eliminator as there will be alot of static in your signal, and you will always hear a slight buzzing.
Headphone connected to the phones output with a 1/4 adapter
You can also look at this guide - https://obsproject.com/forum/resources/q-a-about-dual-pc-stream-audio-setup.156/
Or even search Toms Hardware Forums as there are multiple other posts on this same subject.
