System Specs
Motherboard: ASUS Z9PE-D8 WS
Ram: 8x Samsung M393B2G70BH0-YK0 (16GB DDR3 1600 RDIMM REGISTERED ECC)
Processor: 2x Intel Xeon E5-2680 (v1 Sandy Bridge EP) 130w TDP
Video Card: 4x ASUS GTX 780 Ti 3GB DC2
PSU: 2x Seasonic Prime 1300w Gold Rated
Surge Protector: Tripp Lite LC1800 Voltage Regulating Surge Protector
I've been having issues with the system powering down under load for a while now and trying to get to the bottom of it once and for all.
I basically have it down to Motherboard, CPU's, or RAM. but I feel like the ram is least likely and the CPU's are pretty unlikely also as I've been able to keep system up for solid 5 days with both CPUs at 100% Load. Below is what I've tried.
PSU
Originally had 2x Lepa G1600 Gold PSU so I replaced with 2 new Seasonic PSUs listed above.
I'm using 4 cables on each psu (2 cables per video card) as recommended for video cards with TDP over 225w.for the pci-e connectors 1 cable splits into 2x 8pin connectors
Surge Protector
Also wanted to rule out the surge protector so get a brand new Tripp Lite LC1800, I've also tried plugged directly into outlet.
video cards
I can boot the system no problems and keep GPU under load with one card installed. I get shutdowns under video load with a second card installed in any combination of 2 pcie slots for the first cpu. 3 or 4 cards installed 50/50 won't let me boot into windows unless safe mode or nvidia drivers uninstalled.
Drivers
I Used DDU to uninstall the nvidia drivers (Display, HD Audio, 3D vision, PhysX). Then I was able to perform a regular boot with all 4 cards in so installed nvidia drivers 388.43 from windows updates restarted and powered off before it got to the welcome screen. Rinsed and repeated with the following driver version and no difference.
390.77
387.92
385.12
381.65
Bios
When I started I had Bios version 5601 installed, so I tried latest version 5802 and no difference, so I tried one version previous 5701 no difference.
harddrive
I ran chkdsk /x /r (I have an HDD for boot since bios takes 30 seconds to post anyways) and it found no errors.
add2psu adapter
I tried a different dual psu adapter and I was about to boot into windows with nvidia drivers installed and got really excited. I could put load on any individual card and it was fine but when I put load on all cards instant shut down.
video cards + PSUs in another system
I am able to run all 4 cards max load using new Seasonic PSUs on an old system running with out issues Using nvidia drivers 390.77. So that proves to me the video cards and PSUs are good
Other things I've noticed
I've also noticed that using a wattmeter that I can never manage much over 400w system draw with out it crashing. and when powered off completely the system still draws about 12w but on my old system using both new psu when powered off it was only drawing 0.1w.
What I'm going to try:
I have a know good 4x4gb ddr 3 ram kit I could test with to rule out that but not sure about mobo vs cpu. Since I can run the system for a 5 days straight with both cpu's at 100% utilization with zero crashes but I suppose the cpu's pcie controller portion could be bad? or should I just replace the motherboard? any thoughts?
PSU
Surge Protector
video cards
Drivers
390.77
387.92
385.12
381.65
Bios
harddrive
add2psu adapter
