Dual Same Monitor, Different colours/brightness
kevinmaster5000
26
I had 1 monitor for a year, then I bought the second monitor recently (Both exact models and size 27inches, etc) the Asus VG278H. The second monitor I bought had a vertical stand a bit taller of atleast 2-3 mm. Second monitor, I believe, has darker brightness, making the first monitor more comfortable since it has a brighter screen for some reason with a quite noticeable difference.
which ever link that works
http://imgur.com/ka3hBri,G8zqxeH,rPC0ST3,hRfvOlt,Zsm3X4G,nH0frCU#0
http://imgur.com/a/PVZdA#0
When I compare white, and texts is when you can actually distinguish the main thing I'm concerned with (Should be 6 pictures)
Thank You
Thank you for replying, but if you click on the pictures, I've already tried calibrating them and adjusting colours to as close as I can, any more increase or decreases would completely change it. Plus the brightness of my first to the left monitor is really clear, while the second one is sort of unclear (TEXT comparison picture)
For some reason, the new one (The one on the right) has a bit taller stand which I find weird.
I have the same issue. Asus VS24 8H both plugged into GTX 580. Got 1 a year ago and one a month ago. First one is kind of dark. Whites are somewhat cream colored and the second is really white. Setting are the same on both. Calibration is the same.
Any response would be great!
You need to adjust one or the other to 'look' the same. Exact same settings does not mean exact same look.
Looking at the photos of Kevinmaster5000. It's exactly the same issue. It doesn't matter how I adjust the color settings. If I get the whites to match, the colors are off. If I get black and or colors to match the white is off. What's odd is they did look the same at first. Then I put 2 GTX 750ti's. In. Neither moniter is connected to those cards. They're both connected to the GTX 580.
I should note that I also installed a new Asus z77 pro motherboard. Could the onboard Intel graphics have control of one of them. Device manager and Nvidia control shoes its not, but I did notice my full 16 gigs of ram is not available. It's like 1590GB or something like that.
Unfortunately not a solution guys, but I am having exactly the same issue. I tried calibrating and adjusting the brightness for hours with no result... the colors are completely different. I have the same model - 2 x Asus V5247H.
If anyone has any ideas, then please do help.
Thanks!
