Hi guys,
After a while looking for recommendations at tom's hardware for my next workstation rig, I finally decided to go with a Dual Xeon based build. Here is the list of components:
- Chassis: Thermaltake 91 RGB Tempered Glass
- Motherboard: SuperMicro MBD-X11DAI-N-O
- Processors: 2x Intel Xeon Silver 4114 - 10-Cores 2.2Ghz - Socket 3647 (Scalable Processors Family).
- Heatsinks: Supermicro 4U - SNK-P0070APS4
- Memory 4xRDIMM Crucial (Micron) DDR4 16GB 2666Ghz 1.2 CL19 - Model#: CT16G4RFD8266
- Storage: Samsung 960 Evo M.2 - Nvme PCIe 4x 500GB
- Power Supply: EVGA SuperNova P2 1200w.
- GPU: EVGA FTW3 1080 Ti
Here a few pictures:
Everything went great with the assemble of all the components.
But unfortunately, I ran into an issue when I boot up my system for first time.
There is one Memory module that it's not detected by the BIOS and I can't figure out a solution to this:
Here is the only warning (or message) I can see in the initialization phase (it doesn't always appear, only when I apply a change and save my bios configuration):
P1-DIMMD1: Control Clock Margin Eye width is too small
Here are 2 more screenshots with my CPUs detected, total memory detected and the the memory topology list:
This misconfiguration or memory issue is causing my system to run unstable like, for example: the machine will restart (shuts down and restarts) after a few minutes with no errors (randomly, which I assume... of course this may be related to have unbalanced memory population between both sockets). This also is giving me trouble while trying to install my windows 10 pro from a USB drive to complete the installation since it powers off and back on suddenly.
Have anyone run into this problem before? I started to get a little bit desperate since I've tried to contact supermicro technical support and the answer I received was kinda of vague. They suggested me to swap the CPUs but they didn't mention anything related to the "warning" I'm getting on that specific slot. I also tried to replace with a new memory module, same type and speed (because I thought the old memory module on the slot P1-DIMMD1 of my CPU 1 was defective) but still, the same symptom even with a brand new one. No beeps codes from my internal speaker which I checked with the manual, everything seems perfect except for this.
I will appreciate any recommendations or directions from experts here in the community to see if there is anything else I can do to solve this issue.
I haven't swap the CPUs yet as the technical support from supermicro suggested. I'd rather hear other thoughts before moving forward and try more things. Disassemble the PHMs to switch directions means, cleaning the thermal paste and follow the airflow of the aircoolers, which is a hard job and honestly, the bios seems to detect perfectly the CPUs.
Thank you!
- kuakman
Thank you!
- kuakman
