Dumb question - will Corsair CML16GX3M2A1600C10 memory work with Corsair CML16GX3M2A1600C11?
Bi3oi3
31
Hello folks,
I'm a bit of a newb so forgive my newb question. I want to upgrade the RAM on my PC and add another 16gb. I'm wondering whether Dumb question - will Corsair CML16GX3M2A1600C10 RAM will work with Corsair CML16GX3M2A1600C11 RAM? I figure yes but just wanted to check.
Thanks
CML16GX3M2A1600C10 is 1333mhz where as CML16GX3M2A1600C11 seems to be 1600mhz. But the later could be a discontinued product. Anyways, both should work fine with the later downgrading to the speed of former for operating frequency. But its not recommended to mix rams.
Check cpuz or speccy for exact frequency and clock times and get another of the same for best performance.
