Question Duo PC Stream FPS issues when playing COD MW
Mar 15, 2020
I've recently setup my gaming pc and streaming pc to duo stream. Figured out how to setup audio and display capture. But the problem I'm getting is:
1. Whenever I start up COD MW, it starts at 60 fps. It should be somewhere around the high 100's to 200's. I would have to alt tab out and back in to make it go back to 200's. If I only had to do it once, I wouldn't have an issue. But if I die and get sent to the Gulag, it would go back to 60 fps and I'd have to alt tab out and back in again.
2. Whenever I do this said "alt tab out and in" the elgato 4kHD pro would screen tear on my obs.
If anyone could help fix this issue, you'd literally save a life. Thank you.
