Duplicate Icons In System Tray
  • Thread starter Thread starter Deleted member 244471
  • Start date Start date
D
Guest
Since upgrading to Windows 10 from 7, I have noticed icons duplicating in the system tray. I haven't been able to find a solution online, as everyone else is complaining about icons in the taskbar. The most commonly duplicated icons have been Vuze, Samsung Link, and Norton Antivirus.
Does anyone know a solution or reason for these multiples of icons?
(See attached image)
view
In case the image link doesn't work, here is the direct link to the screenshot on my google drive.
https://drive.google.com/file/d/0BzWarDPRzxt6MlYtU050elpvdnc/view?pli=1
Thank you!
Hi there,
There is a simple fix for this as I have had the same sort of problem in Windows 7.
Download this program here.
http://download.cnet.com/Notification-Area-Cleaner-64-Bit/3000-18512_4-75852358.html
It's relatively easy to use, you should be able to figure it out, the program basically resets the icon cache on the system tray, it should fix your issue. Be sure to restart your PC after using the program to make sure it has worked properly!
Post back results here!
Hope I helepd! :d
Hi there,
Hope I helepd! :d
