Hello all,
Based on the photos below, what do you think has caused the burned power plug area on my DVD burner?
1. DVD Burner gone bad?
2. Power adapter (molex) gone bad?
3. Power supply issue?
4. other
I'm assuming it was #1 or #2 and I will replace both since they are burnt, but I wanted to check with you if I should be concerned about anything else, e.g., motherboard, power supply.
Thanks!
The system is an i7-920 cpu (no OC'ing), asus p6t motherboard, antec cp850 power supply, so it's a little older but still going strong. and the DVD burner is an LG GH20LS15.
4. other
Thanks!
