DVD drive not working
_aragon_
44
Hi,
I have a lenovo b570 laptop which came with a Slimtype DVD A DS8A5SH (dvd writer/reader). The problem is when i put in a dvd the reader does not read it and even does not give any errors.The green light on the panel where i put dvd only blinks for a second and then shuts of. There is also no sound of dvd moving as there was earlier(only a slight noise) when it was ok.
The following specs are from speccy software---
Media Type DVD Writer
Name Slimtype DVD A DS8A5SH
Availability Running/Full Power
Capabilities Random Access, Supports Writing, Supports Removable Media
Read capabilities CD-R, CD-RW, CD-ROM, DVD-RAM, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-R DL, DVD+R DL
Write capabilities CD-R, CD-RW, DVD-RAM, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-R DL, DVD+R DL
Config Manager Error Code Device is working properly
Config Manager User Config FALSE
Drive G:
Media Loaded FALSE
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 0
SCSI Target Id 1
Status OK
Guys please help me as i frequently need the writer to make and submit presentations.
Things tried-
1. Re installing drivers.
Hi, maybe you have a bad contact at the connector for the DVD, take out the DVD drive, you should have just one screw to remove, and put it back after. It's worth a try, you have nothing to lose if it fixes the problem.
Thanks for your suggestion i will check it out and tell if it worked or not.:ange:
