Please keep it to 1 thread
My Asus DVD drive doesn't open the tray and when it opens it's 80% out I need to fix it but I don't know
rubber photo
https://ibb.co/Hgm4gDY
rubber photo
They will fix or replace so that it works as advertised.i bought an asus sata dvd drive with mdisc support but it failed to fully lock the drawer i called the warranty and they said the product can be repaired by them or exchanged for a new one, the doubt: if they repair it, there is a risk of replace any parts that make the drive lose support for M-Disc?
the problem of the dvd drive tray not opening 100% but opening 80% is a serious problem that I cannot solve personally and I have to go through all the bureaucracy to trigger the warranty and send the drive?Do not buy a belt. You have little or no control over that belt really fitting, working, and lasting.
Plus you may do more damage to the drive trying to replace the belt.
If you attempt any repairs on your own then support will certainly be lost.
You could have ASUS do the work and if the repairs fail then they are responsible. That could take lots of time for shipping back and forth. plus repairs themselves.
Lots of time.....
As I understand your posts, ASUS has offered a new replacement DVD. If so, then simply exchange for a new DVD drive.
Perhaps the new drive and its' component parts will last longer.
Keep all documentation - just in case.
Unless you have a UV and oxygen free, temperature controlled environment...you cannot store a rubber belt for "the future".the problem of the dvd drive tray not opening 100% but opening 80% is a serious problem that I cannot solve personally and I have to go through all the bureaucracy to trigger the warranty and send the drive?
do you have any asus sata dvd drive belt with more resistant material that i can store to change in the future?
for the UV belts I protect by keeping them inside closed boxes but humidity I don't have an airtight environment, I thought about buying some belts to store and repair in the future because in the future I don't know if they will be for saleUnless you have a UV and oxygen free, temperature controlled environment...you cannot store a rubber belt for "the future".
